[GRASSLIST:4605] Re: Transparent null values in output images.
Gordon Keith
gordon.keith at csiro.au
Thu Oct 21 17:50:22 EDT 2004
On Wed, 20 Oct 2004 23:01, Hamish wrote:
> > I have some rasters with large null areas.
> > I would like to output these as images (r.out.png or r.out.tiff) with
> > the null values represented by transparent pixels.
> > I can't see any flags on these commands to enable this.
> > Is this possible?
> some clues:
> set $GRASS_TRANSPARENT to "TRUE"
> then d.out.png (or d.mon start=PNG etc)
> Set $GRASS_WIDTH & $GRASS_HEIGHT to region settings for cols & rows to
> get 1:1 scaling (as with r.out.png).
> d.out.png then merge alpha in the GIMP?
> r.out.ppm -> gimp?
If I'm going to have to resort to GIMP it's probably easier just to use
r.out.png then GIMP:
Edit - Layers - Add alpha channel
Edit - Select - by colour - click on white
Edit - Cut (Ctrl-X)
File - Save
But it does look like
r.out.ppm raster
does the job nicely.
Thanks for pointing me in the right direction.
Thought: is it worth mentioning this in the r.out.ppm man page?
Regards
Gordon
Gordon Keith
Programmer/Data Analyst
Marine Acoustics
CSIRO Marine Research
http://www.marine.csiro.au
To mess up a Linux box, you need to work at it;
to mess up your Windows box, you just need to work on it.
- Scott Granneman, SecurityFocus
