[GRASSLIST:4688] Re: from line to polygon
Markus Neteler neteler at itc.it
Fri Oct 29 10:56:20 EDT 2004
On Thu, Oct 28, 2004 at 01:15:55PM -0400, DrakeGis wrote:
> Hi Helli,
>    I guess that in GRASS 5.3 you could use
> 1) v.line2area
> 2) v.out.e00
>   I'm not sure about how to do it in GRASS 5.7
Use v.type:
http://grass.itc.it/grass57/manuals/html57_user/v.type.html
Convert lines to area boundaries
 v.type input=map_l output=map_b type=line,boundary
To make it polygons, you will have to add centroids.
Markus
> > Hi GRASS friends,
> > I am very new in using GRASS (5.3, 5.7, LINUX). I have two questions:
> > 1) I have a line-Shape-file, in which areas (vegetation types) are
> > digitized. After importing into GRASS, is it possible to convert the lines
> > into polygones?
> > 2) Is it possible to export these polygones in Arc/Info-e00-format?
> > Thanks with greetings from Tyrol
> > Helli
