[GRASSLIST:4308] Re: 6s input file
Markus Neteler neteler at itc.it
Mon Sep 6 02:32:24 EDT 2004
On Sat, Sep 04, 2004 at 10:18:07PM +0200, Maciek Sieczka wrote:
> Hi All!
> I'd like to try the 6s i.atcorr on a Landsat 7 scene. I managed to get the
> module running but I'm having problems with making the txt input file with
> parameters. If someone could share such a file I would be gratefull. I have
> already found
> http://www.ltid.inpe.br/dsr/mauro/6s/ETM4_atmospheric_input.txt but it seems
> different than what i.atcorr wants (or I don't understand the i.atcorr
> manual).
> Markus!
> Some time ago you mentioned your i.run.6s script for Landsat 5 on the
> mailing list. Would you mind sending it to me or putting it somewhere for
> download?
You can grab it here:
http://mpa.itc.it/markus/grass53/i.run.6s_script.tar.gz
(360k, including 6S for linux from some years ago)
I didn't test it recently but used it successfully in 1999.
Markus
