[GRASSLIST:4327] Re: exporting vector with different fields
Radim Blazek
blazek at itc.it
Thu Sep 9 07:41:27 EDT 2004
On Thursday 09 September 2004 12:55, ivan marchesini wrote:
> Hi to all grass users, we need a suggestion:
> We have created a vector map which contains two fields. Some vectors are
> connected to a table (wood.dbf) in field n°1. Others are connected to a
> different table (landuse.dbf) in field n°2.
> Now I would need to export the vector files to .shp format but the use
> of v.out.ogr requires to choose which field to export (only one) but we
> need to export two fields.
> Suggestions? Comments?
You have to create 2 shapefiles, i.e. to run v.out.ogr twice.
Shapefile cannot store more layers.
Radim
