[GRASSLIST:4414] v.to.sites error
    Maciek Sieczka
    werchowyna at pf.pl
    Fri Sep 24 14:16:31 EDT 2004
Hi!
It seems that v.to.sites fails to translate some points near the nodes.
Ater doing as follows:
GRASS:~ > v.to.sites -a -i input=rzezba output=site_rzezba dmax=1
   v.to.sites:
Number of vector nodes = 138
Number of sites generated = 162789
[Raster MASK present]
I get a result a piece of which you can see on the vtosites.png, where:
-RED is the input vector file "rzezba" (height contour lines and height
sites)
-WHITE is the output site file site_rzezba
-GREEN arrows indicate sections of the input vector not translated to
sites - near the nodes
Unclosed line's endings are not translated either.
This error does not depend on dmax.
DEVELOPERS! Should I give a bug report?
Maciek
P.S.
I wonder if v.surf.rst uses a smililar way to translate the input vector
lines to points thus commit the same error?
Maciek
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20040924/53699e14/vtosites.png
