[GRASSLIST:4431] Re: v.to.sites error
Maciek Sieczka werchowyna at pf.pl
Wed Sep 29 17:36:26 EDT 2004
> Categories in 5.0/5.3 can be easily lost and labeling
> algorithm can differ in modules.
> Important is output from v.what.vect on that part of line.
> Radim
v.what.vect?
if you mean an output from d.what.vect then it's ok within the whole line
lenght including the part where v.to.sites fails
also when I display labelled lines and their lables in v.digit all is fine
but after the v.to.sites such line is not converted near the node
here are two more pictures to see how is the node located (YELLOW on
vdigit.png) in respect to the v.to.sites result (WHITE sites on the
dsitesdvect.png)
> On Tuesday 28 September 2004 22:16, Maciek Sieczka wrote:
> > Radim,
> > one new thing about this error
> > v.to.sites fails near the nodes as described before if the vector lines
are
> > prepared in v.digit but it doesn't when the vector lines are produced
using
> > the r.contour on a dem raster
> > please see the attached vtosites_2.png for comaprison, where
> > VIOLET - vector lines
> > WHITE - sites produced with v.to.sites
> > the inner circle was digitized and labelled in v.digit, then v.to.sites
> > the outer circle was derived from a DEM with r.contour, then v.to.sites
> > could it be that v.digit is guilty?
> > (all refers to Grass5.3)
> > Maciek
> > ----- Original Message -----
> > From: "Maciek Sieczka" <werchowyna at pf.pl>
> > To: <grasslist at baylor.edu>
> > Sent: Tuesday, September 28, 2004 12:08 AM
> > Subject: [GRASSLIST:4419] Re: v.to.sites error
> > > > > It seems that v.to.sites fails to translate some points near the
> > nodes.
> > > > > Unclosed line's endings are not translated either.
> > > > > This error does not depend on dmax.
> > > > > DEVELOPERS! Should I give a bug report?
> > > > > Maciek
> > > > > P.S.
> > > > > I wonder if v.surf.rst uses a smililar way to translate the input
> > vector
> > > > > lines to points thus commit the same error?
> > > Radim wrote:
> > > > Similar maybe, but not the same. Are you sure, that those lines have
a
> > > > category?
> > > yes I'm sure
> > > each closed line has one node
> > > the closed lines fail to convert to sites near that node
> > > open lines have two nodes - one on each ending
> > > open lines fail to convert to sites near the nodes on the line's
endings
> > > I worked the error around doing v.to.rast and then r.to.sites
> > > Maciek
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20040929/e432167b/vdigit.png
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20040929/e432167b/dsitesdvect.png
