[GRASSLIST:4436] Re: bug fixes for tcltkgrass for GRASS 5.3
Paul Kelly
paul-grass at stjohnspoint.co.uk
Thu Sep 30 10:36:15 EDT 2004
On Thu, 30 Sep 2004, Hamish wrote:
>>>> BTW - what is the r.surf.idw2 for anyway when it is slower, less
>>>> universal and gives identical results. Strange... Ask Grass developers?
>>> I don't know what the difference is either.
>> Can anybody say if there are any more diffrences between the r.surf.idw2
>> and *idw which justify both them being available?
They use two different algorithms. They should probably be merged into one
module, and then either use a heuristic method to decide which algorithm
is most appropriate for the data, or a command-line switch to determine
the algorithm used. Kind of like s.surf.idw, which has a command-line
switch to use a different algorithm from the default.
