[GRASSLIST:6327] Re: INSTALLATION PROBLEM
    Massimiliano Cannata
    massimiliano.cannata at supsi.ch
    Mon Apr  4 09:55:00 EDT 2005
Hello francesco,
thanks for the WIND file but also this one gives me the same error....
GRASS 6.0.0 (test2):/usr/local/src/grass-6.0.0 > g.region -p
ERROR: default region is invalid
       line 11: <top: 1>
the error comes from the line with:
G_get_default_window (&window);
here there something wrong... but i cannot guess what.....
thanks,
Maxi
francesco wrote:
> Hello Massimiliano
> Try changing the wind file to a simpler format.  I include a simple
> wind file.  You can then change the parameters one by one to identify
> the problem in your wind file
> Ciao
> Francesco Pirotti
> CIRGEO
> Centro Interdipartimentale di Ricerca in Cartografia
> Fotogrammetria, Telerilevamento e S.I.T.
> Università degli Studi di Padova
> Viale dell'Università 16 - Legnaro - PD
> www.cirgeo.unipd.it
> tel.  +39.328.2126861
> tel.  +39.049.827.2522/2688
> fax. +39.049.8272686
_____________________________________________________
Ing. Massimiliano Cannata
SUPSI - Istituto Scienze della Terra
C.P. 72 - CH-6952 Canobbio (Ticino, Switzerland)
Tel +41 (0)91 935 12 25 - Fax +41 (0)91 935 12 09
mailto:massimiliano.cannata at supsi.ch
http://www.ist.supsi.ch
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20050404/428f050d/attachment.html
