[GRASSLIST:6369] Re: i.maxlike does not read sig file
Martin Wegmann
wegmann at biozentrum.uni-wuerzburg.de
Fri Apr 8 08:23:26 EDT 2005
Hallo Jachym,
On Friday 08 April 2005 13:00, you wrote:
> ls $GISDBASE/$LOCAION_NAME/$MAPSET/group/all_img/subgroup/all_img_sub/
> ist all_img_sig irgendwo in irgendeinem unterverzeichniss?
yes, the sig file is there.
I tried the same with the spearfish data set and did the same with i.group
i.cluster and then i.maxlik -- it worked, I received an output map.
Hence my data set must cause i.maxlik not to find the sig file, doesn't it?
Martin
P.S.:These warnings appeared as well:
i.maxlik group=test subgroup=test_sub sigfile=test_sig class=test_class
WARNING: signature 64 is not valid (ill-conditioned) - ignored
WARNING: signature 73 is not valid (ill-conditioned) - ignored
i.maxlik ...
