Has anyone had any luck using the results from r.terraflow in r.water.outlet? More specifically I want to use the output direction grid from r.terraflow for the drainage direction map input of r.water.outlet. The r.water.outlet documentation only refers to using a drainage direction map generated in r.watershed.
