[GRASSLIST:6418] Re: gdal with grass
    orkun
    temiz at deprem.gov.tr
    Mon Apr 11 23:58:13 EDT 2005
thank you for interest
when I looked up the errors to answer you.
I did not understand what happened but it worked somehow.
like this way :
orkun at landslide:/usr/local/gdal-1.2.6/.libs$ ldd libgdal.so.1.7.0 | grep
"grass"
        libgrass_I.so => /usr/lib/grass/lib/libgrass_I.so (0x4040f000)
        libgrass_vask.so => /usr/lib/grass/lib/libgrass_vask.so
(0x40420000)
        libgrass_gmath.so => /usr/lib/grass/lib/libgrass_gmath.so
(0x40426000)
        libgrass_gis.so => /usr/lib/grass/lib/libgrass_gis.so
(0x4042c000)
        libgrass_datetime.so => /usr/lib/grass/lib/libgrass_datetime.so
(0x404b5000)
regards
On Pzt, 2005-04-11 at 23:44 -0400, Frank Warmerdam wrote:
> On Apr 11, 2005 10:59 PM, orkun <temiz at deprem.gov.tr> wrote:
> > thank you
> > I am going to use mapserver and get grass maps/
> > I think the only way is to compile gdal with grass support.
> > But is there a conflict of grass6 with gdal ?
> Orkun,
> My suggestion would be to:
>  o configure, and install GDAL "--without-grass".
>  o configure and install GRASS 6.
>  o re-configure GDAL --with-grass and do "make clean; make; make install".
> Alternatively you could build the GRASS driver for GDAL as a plugin
> after building and installing GRASS but that has complications too.
> Best regards,
______________________________________
XamimeLT - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster at deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
