[GRASSLIST:6473] Re: r.terraflow weirdness
    Hamish
    hamish_nospam at yahoo.com
    Thu Apr 14 18:47:43 EDT 2005
> I'm getting a "stats.out: Permission denied" error with r.terraflow,
> but the output directory is clearly owned by me (I've changed it to a
> number of different directories).  Any ideas?  I was able to run this
> a few days ago, I don't know what's changed...
what about setting the STREAM_DIR= option? maybe you don't have
permissions in the /var/local dir for the temp files?
(using /var/local is a known bug, it should use $MAPSET/.tmp/$HOST/)
Hamish
