[GRASSLIST:6487] Re: use of c_minx and c_maxx in r.series
Glynn Clements
glynn at gclements.plus.com
Thu Apr 14 21:51:46 EDT 2005
vincent at ecovla.nl wrote:
> > > What you describe will give me an output raster file which is in fact
> > > an index referring to my input series of raster files, right? Now what
> > > I want to do is use this result, the index raster, to get values from
> > > comparable but different raster series, e.g. different bands of the
> > > same time series. My problem is not how to define the series or have
> > > them as input using g.mlist, I know how to do that. My problem is that
> > > I want to do e.g. r.series.fromindex input=$series_red
> > > index=$output_of_min_x.
> > x=1
> > r.mapcalc if(index==$x)
> > for each step then r.patch all the parts together?
> Hmm it's a solution, but not really what I hoped for: something more
> efficient, and easier to use. Maybe I'll try to create an
> r.series.fromindex...
Currently, there isn't any better approach than the one which Hamish
suggested.
It wouldn't be a lot of work to make a copy of r.series (you only need
main.c) then modify it to do what you need. I've attached a draft
version (untested).
#include <string.h>
#include <stdlib.h>
#include <unistd.h>
#include "gis.h"
#include "glocale.h"
struct input
char *name, *mapset;
int fd;
DCELL *buf;
int main(int argc, char *argv[])
struct GModule *module;
struct {
struct Option *index, *input, *output;
} parm;
struct {
struct Flag *quiet;
} flag;
int verbose;
int i;
char *idx_name, *idx_mapset;
int idx_fd;
CELL *idx_buf;
int num_inputs;
struct input *inputs;
char *out_name;
int out_fd;
DCELL *out_buf;
int nrows, ncols;
int row, col;
G_gisinit(argv[0]);
module = G_define_module();
module->description =
_("Selects each cell from one of the input maps "
"according to the cell value from the index map.");
parm.index = G_define_option() ;
parm.index->key = "index" ;
parm.index->type = TYPE_STRING ;
parm.index->required = YES ;
parm.index->multiple = NO ;
parm.index->gisprompt = "old,cell,raster" ;
parm.index->description= _("Names of existing raster files") ;
parm.input = G_define_option() ;
parm.input->key = "input" ;
parm.input->type = TYPE_STRING ;
parm.input->required = YES ;
parm.input->multiple = YES ;
parm.input->gisprompt = "old,cell,raster" ;
parm.input->description= _("Names of existing raster files") ;
parm.output = G_define_option() ;
parm.output->key = "output" ;
parm.output->type = TYPE_STRING ;
parm.output->required = YES ;
parm.output->gisprompt = "any,cell,raster" ;
parm.output->description= _("Name of the new raster file") ;
flag.quiet = G_define_flag();
flag.quiet->key = 'q';
flag.quiet->description = _("Run quietly");
if (G_parser(argc,argv))
exit(1);
verbose = !flag.quiet->answer;
/* process the index map */
idx_name = parm.index->answer;
idx_mapset = G_find_cell2(idx_name,"");
if (!idx_mapset)
G_fatal_error("raster file <%s> not found", idx_name);
idx_fd = G_open_cell_old(idx_name, idx_mapset);
if (idx_fd < 0)
G_fatal_error("unable to open index map <%s> in mapset <%s>",
idx_buf = G_allocate_c_raster_buf();
/* process the input maps */
for (i = 0; parm.input->answers[i]; i++)
num_inputs = i;
inputs = G_malloc(num_inputs * sizeof(struct input));
for (i = 0; i < num_inputs; i++)
struct input *p = &inputs[i];
p->name = parm.input->answers[i];
p->mapset = G_find_cell2(p->name,"");
if (!p->mapset)
G_fatal_error("raster file <%s> not found", p->name);
p->fd = G_open_cell_old(p->name, p->mapset);
if (p->fd < 0)
G_fatal_error("unable to open input map <%s> in mapset <%s>",
p->buf = G_allocate_d_raster_buf();
/* process the output map */
out_name = parm.output->answer;
out_fd = G_open_raster_new(out_name, DCELL_TYPE);
if (out_fd < 0)
G_fatal_error("unable to create output map <%s>", out_name);
out_buf = G_allocate_d_raster_buf();
/* initialise variables */
nrows = G_window_rows();
ncols = G_window_cols();
/* process the data */
if (verbose)
fprintf(stderr, "Percent complete ... ");
for (row = 0; row < nrows; row++)
if (verbose)
G_percent(row, nrows, 2);
G_get_c_raster_row(idx_fd, idx_buf, row);
G_get_d_raster_row(inputs[i].fd, inputs[i].buf, row);
for (col = 0; col < ncols; col++)
CELL idx = idx_buf[col];
if (G_is_c_null_value(&idx) || idx < 0 || idx >= num_inputs)
G_set_d_null_value(&out_buf[col], 1);
else
memcpy(&out_buf[col], &inputs[idx].buf[col], sizeof(DCELL));
G_put_d_raster_row(out_fd, out_buf);
if (verbose)
/* close maps */
G_close_cell(out_fd);
G_close_cell(inputs[i].fd);
G_close_cell(idx_fd);
exit(0);
