[GRASSLIST:6494] Re: m.proj s.in.ascii s.to.rast
Maciek Sieczka werchowyna at epf.pl
Fri Apr 15 15:13:15 EDT 2005
Hi
Sites no longer exists in 5.7+. Replaced by vector points. Thus:
s.in.ascii = v.in.ascii
m.proj2 = v.proj
s.to.rast = v.to.rast
Or go for the "old" Grass 5.4 - much improved and cleaner than 5.0, easy to
build, and still using sites. However note that there will be no more
developmnet in the 5.x branch, we may expect only releases fixing major
bugs. So the sooner we users get used to new vector engine the better for us
Maciek
----- Original Message -----
To: <GRASSLIST at baylor.edu>
Sent: Friday, April 15, 2005 7:11 PM
Subject: [GRASSLIST:6493] m.proj s.in.ascii s.to.rast
> Hi,
> I just installed GRASS6.0, the installation was a lot easier (as I recall)
> than installing 5.0 a year ago.
> Last time I worked with GRASS (Feb 2004), I was trying to calculate the
> landcover statistics in a 500km radius around a research site using the
> NLCD from USGS:
> a)  I used m.proj2 to convert my site location to the appropriate
> projection.
> b)  defined the site with s.in.ascii, and converted it to a raster using
> s.to.rast.
> c)  created the buffer zone using r.buffer
> d)  patched the landcover map in the buffer zone with r.patch -z
> e)  calculated statistics with r.stat -c
> What happened to m.proj(2), s.in.ascii, and s.to.rast?
> I gather these commands no longer exist. In that case I need some help
> figuring out how to do this in 6.0.
> Thanks.
> Martin
> [Originally posted to win-Grass, so I apologize for multiple posting]
