[GRASSLIST:6510] Re: r.water.outlet
Eric Hillmuth
hillmuth at verizon.net
Sun Apr 17 09:04:43 EDT 2005
I did try r.terraflow initially but in this case r.fill.dir is much
faster because all I need is flow direction, not flow accumulation, TCI
or any of the other things r.terraflow provides. Also, I was never able
to figure out how to get the flow direction r.water.outlet needs from
the r.terraflow flow direction (I was the guy that started that thread
you mentioned). Regardless of what I use to get flow direction it would
be helpful to know what format r.water.outlet expects, ie what
direction is 1 North, East or something else.
Thanks very much, I appreciated the help
Hamish wrote:
>>I'm having trouble coming up with the drainage direction input for
>>r.water.outlet. The documentation indicates that the input should come
>>from r.watershed but I'm working with large DEMs and r.watershed is
>>too slow.
>try r.terraflow.
>>It seems like I should be able to use flow direction from
>>r.fill.dir in AGNPS format but it doesn't work out. r.fill.dir
>>produces flow direction as 1-8 with 1 being North. R.water.outlet
>>takes flow direction input as 1-8 but I'm unsure of the if 1 is
>>North. I suspect 1 is East but I'd appreciate any ideas.
>see this thread as well:
> http://grass.itc.it/pipermail/grassuser/2005-April/028515.html
>Hamish
