[GRASSLIST:6509] Re: r.water.outlet
Hamish
hamish_nospam at yahoo.com
Sun Apr 17 00:34:40 EDT 2005
> I'm having trouble coming up with the drainage direction input for
> r.water.outlet. The documentation indicates that the input should come
> from r.watershed but I'm working with large DEMs and r.watershed is
> too slow.
try r.terraflow.
> It seems like I should be able to use flow direction from
> r.fill.dir in AGNPS format but it doesn't work out. r.fill.dir
> produces flow direction as 1-8 with 1 being North. R.water.outlet
> takes flow direction input as 1-8 but I'm unsure of the if 1 is
> North. I suspect 1 is East but I'd appreciate any ideas.
see this thread as well:
http://grass.itc.it/pipermail/grassuser/2005-April/028515.html
Hamish
