[GRASSLIST:6511] Re: import of dxf files in grass6.0
Markus Neteler
neteler at itc.it
Sun Apr 17 15:33:20 EDT 2005
On Fri, Apr 15, 2005 at 02:04:24PM +0200, Grégoire Pigeon wrote:
> Good afternoon,
> I've installed the grass 6.0 version. I was trying to import dxf files
> and I don't see any more v.in.dxf function. I don't find other solution
> to import dxf files. Is there another function available for that ?
> Thanks for your help.
> Gregoire Pigeon
Please have a look here if you are missing a certain command:
http://grass.gdf-hannover.de/twiki/bin/view/GRASS/ModulePortingList
-> v.in.dxf - replaced by v.in.dwg (note: cannot be compiled by
default or distributed in binary)
-> http://grass.gdf-hannover.de/twiki/bin/view/GRASS/GrassSixTutorialFaq#2_DXF_and_DWG_files
"DXF and DWG files"
Q: How to import DXF/DWG files?
A: There are legal conflicts between the required 'openDWG' library and the GRASS GPL. We are not allowed to distribute the library (so the module) along with the GRASS code. Please see the v.in.dwg HTML page for further details (or http://mpa.itc.it/markus/tmp/v.in.dwg.html )
Hope this helps
Markus
