[GRASSLIST:6517] Re: vector line width display
Glynn Clements
glynn at gclements.plus.com
Sun Apr 17 21:10:11 EDT 2005
Teague O'Mara wrote:
> Is there a way to change the weight/width of a displayed vector line to make
> it wider than 1 pixel?
No.
> This is a question that came up earlier, but I thought that I'd ask again.
> In January the answer someone else received was no. If this is still true,
> would it be possible to alter the display driver to give this option
> (apologies for my ignorance about that part).
You could modify the display driver, but there are likely to be
programs which wouldn't behave correctly with the modified driver. The
line-drawing functions aren't used solely for drawing vector maps.
> Just checking to see if this has changed possibly in 6.0.
No, nothing has changed in that regard.
