[GRASSLIST:6518] Re: vector line width display
Sun Apr 17 22:15:43 EDT 2005
> Is there a way to change the weight/width of a displayed vector line to make
> it wider than 1 pixel?
with d.vect the answer is no, but there are always other paths:
a) use ps.map which can do it
b) use v.buffer and then d.vect the resultant area
c) use QGIS's GRASS plugin to load & render the map, which can do it
Hamish
