[GRASSLIST:6524] Re: r.water.outlet
Giacomo Bertoldi
giacomo.bertoldi at ing.unitn.it
Mon Apr 18 09:02:27 EDT 2005
Drainage direction needed by r.water.outlet:
N: this means that water is going to North ...
N: 2
N/E: 1
E: 8
S/E: 7
S: 6
S/W: 5
W: 4
N/W: 3
Giacomo
>>>> I'm having trouble coming up with the drainage direction input for
>>>> r.water.outlet. The documentation indicates that the input should
>>>> come from r.watershed but I'm working with large DEMs and
>>>> r.watershed is too slow.
Try r.terraflow for large dataset.
> try on a small area and compare outputs.
>>>> It seems like I should be able to use flow direction from
>>>> r.fill.dir in AGNPS format but it doesn't work out. r.fill.dir
>>>> produces flow direction as 1-8 with 1 being North. R.water.outlet
>>>> takes flow direction input as 1-8 but I'm unsure of the if 1 is
>>>> North. I suspect 1 is East but I'd appreciate any ideas.
> for the record, here's some aspect map format information collected
> from
> the help pages and source code:
> (use d.rast.arrow and d.rast.num to investigate AGNPS, ANSWERS, GRASS
> formats)
> AGNPS (r.fill.dir)
> category values from 1-8, with 1 facing north and increasing values in
> the clockwise direction.
> ANSWERS (r.fill.dir)
> category values from 0-360 degrees, with 0 (360) facing east and values
> increasing in the counter clockwise direction at 45 degree increments.
> GRASS (r.fill.dir)
> broken in 6.0.0. (was old GRASS 4? format) In the old days
> (pre-floating
> point GRASS rasters) there was a 24-points based GRASS aspect map
> format
> which still rears its ugly head sometimes:
> 24,1,2 east
> 3,4,5 north east
> 6,7,8 north
> 9,10,11 north west
> 12,13,14 west
> 15,16,17 south west
> 18,19,20 south
> 21,22,23 south east
> GRASS (r.slope.aspect, others)
> categories represent the number degrees of east and they increase
> counterclockwise: 90deg is North, 180 is West, 270 is South and 360 is
> East. Beware: 0 may be null! Similar to the ANSWERS format AFAICT.
> r.param.scale
> the direction of maximum gradient (considered downslope) is stored as
> (West is 0 degree, East is +/- 180 degree):
> * 0..+180 degree from West to North to East
> * 0..-180 degree from West to South to East
> [Anomaly: I vote for changing this to standard GRASS5 aspect format]
> r.watershed drainage map (what r.water.outlet wants)
> drainage direction. Provides the "aspect" for each cell. Multiplying
> positive values by 45 will give the direction in degrees that the
> surface runoff will travel from that cell. The value -1 indicates that
> the cell is a depression area (defined by the depression input map).
> Other negative values indicate that surface runoff is leaving the
> boundaries of the current geographic region. The absolute value of
> these
> negative cells indicates the direction of flow.
> [should we change this to standard AGNPS(+neg flag) aspect format ??]
> It would be nice to get these down to AGNPS, ANSWERS, and GRASS format
> anyway.
> so AGNPS is not the same as r.watershed format, but 45deg off:
> dir AGNPS r.watershed
> N 1 0 or 8 ?
> NE 2 1
> E 3 2
> SE 4 3
> S 5 4
> SW 6 5
> W 7 6
> NW 8 7
> fix:
> r.mapcalc 'aspect.watershed = if(aspect.AGNPS == 1, 8, \
> if(aspect.AGNPS > 1 && aspect.AGNPS <= 8, aspect.AGNPS-1, null() ))'
> if that works we can add it to the help page. (looks ok to me)
> note the negative values from the watershed program will be lost, which
> might adversely affect the output of r.water.outlet! (no idea)
>> I did try r.terraflow initially but in this case r.fill.dir is much
>> faster because all I need is flow direction, not flow accumulation,
>> TCI or any of the other things r.terraflow provides.
> ok
>> Also, I was never able to figure out how to get the flow direction
>> r.water.outlet needs from the r.terraflow flow direction (I was the
>> guy that started that thread you mentioned).
> Oh sorry, only short term memory here.
> FYI, I've whipped up a Matlab script to extract the dominant flow
> direction from the r.terraflow MFD output map and reclass it into
> the GRASS aspect format for use with d.rast.arrow, etc. It should
> be easy enough to rewrite it in something more Free and convert the
> export into any of the above aspect formats by changing asp_mtx[].
> Usually you can just use r.slope.aspect directly as a proxy.
> find it here:
> http://grass.gdf-hannover.de/twiki/bin/view/GRASS/GrassAddOns
>> Regardless of what I use to get flow direction it would be helpful to
>> know what format r.water.outlet expects, ie what direction is 1
>> North, East or something else.
> AFAICT: 1 is NE, moving around the compass clockwise until 8 is North,
> and mind the negative values and information lost by taking the
> absolute
> value of flow direction.
> Hamish
