[GRASSLIST:6537] Re: problem importing vector
Trevor Wiens
twiens at interbaun.com
Mon Apr 18 22:57:54 EDT 2005
On Mon, 18 Apr 2005 19:38:55 -0400
Brian Beckage <Brian.Beckage at uvm.edu> wrote:
> Dear Lorenzo,
> Thank you for your reply. I installed the Jump software as you
> suggested, opened the old shape file, and saved it under a new name
> (still .shp) in a new folder. When I tried importing it into Grass,
> the error now was:
> ERROR: Projection of dataset does not appear to match current location.
> I don't have this error when using the original shape files.
> Are there any other work arounds? Can I try importing this vector
> file using a different format such as .e00?
> Thanks again,
> Brian
Click on the override projection button if you are importing through the gui or use -o if you are using command line. This will work fine if your projections actually match but the shape file is lacking the information.
T
Trevor Wiens
The significant problems that we face cannot be solved at the same
level of thinking we were at when we created them.
(Albert Einstein)
