[GRASSLIST:6533] Re: problem importing vector
Brian Beckage Brian.Beckage at uvm.edu
Mon Apr 18 19:38:55 EDT 2005
Dear Lorenzo,
Thank you for your reply.  I installed the Jump software as you
suggested, opened the old shape file, and saved it under a new name
(still .shp) in a new folder.  When I tried importing it into Grass,
the error now was:
ERROR: Projection of dataset does not appear to match current location.
I don't have this error when using the original shape files.
Are there any other work arounds?  Can I try importing this vector
file using a different format such as .e00?
Thanks again,
Brian
At 5:56 PM +0200 4/18/05, Lorenzo Moretti wrote:
>Hi Brian
>>Hello,
>>I'm new to GRASS (and to GIS).  I'm having trouble importing a
>>vector file (using v.in.ogr) of the Everglades coastline in
>>Florida, USA. The coastline is very irregular with many small
>>islands.  My machine has been working for three days, appears to be
>>making progress (e.g., the line number at the bottom of the output
>>shown below keeps increasing), albeit slowly.  I estimate that it
>>will take about a week to complete this import.  I'm using Grass
>>6.0 on Mac OSX and the output is displayed below.  My specific
>>questions are:
>>1.  Should I wait a week for this to complete, e.g., is it likely
>>to successfully complete this import, or is the long time required
>>indicative of a problem?
>>2.  Is there a faster way of accomplishing this import?
>>Thanks for your help,
>>Brian
>>>v.in.ogr
>>>dsn=/Users/PROJECTS/ENP/Plot_Info/GIS/PaulsCD/k24bound.shp
>>>output=k24bound
>>A datum name nad27 (North_American_Datum_1927) was specified
>>without transformation parameters.
>>WARNING: Non-interactive mode: the GRASS default for nad27 is
>>          towgs84=-22.000,157.000,176.000.
>>Projection of input dataset and current location appear to match.
>>Proceeding with import...
>>Layer: k24bound
>>Building topology ...
>>18233 primitives registered
>>Building areas:  100%
>>18233 areas built
>>18233 isles built
>>Attaching islands:  100%
>>Attaching centroids:  100%
>>Topology was built.
>>Number of nodes     :   18233
>>Number of primitives:   18233
>>Number of points    :   0
>>Number of lines     :   0
>>Number of boundaries:   18233
>>Number of centroids :   0
>>Number of areas     :   18233
>>Number of isles     :   18233
>>Number of areas without centroid :   18233
>>WARNING: Cleaning polygons, result is not guaranteed!
>>Topology was built.
>>Number of lines     :   0
>>Number of areas     :   -
>>Number of isles     :   -
>>Break polygons:
>>Registering points ... 745775
>>All points (vertices): 764031
>>Registered points (unique coordinates): 745775
>>Points marked for break: 18254
>>Breaks:    65
>>Remove duplicates:
>>Duplicates:     0
>>Break boundaries:
>>Intersections: 297999 (line 89173)
>This is an old problem from grass 5.7. Grass with some shape files
>(only some) goes to infinite loop in Mac OS X only.
>This is a bug unresolved: send a new report in the bug list at
>http://grass.itc.it/bugtracking/bugreport.html with the description.
>Try this method: open this shape in Jump (you see the link in my
>site below), check the draw and the data and resave this shape file
>with a new name. Inside Jump there is a my doc to export shape file
>from Jump. Now import this new shape file inside Grass and check.
>Sometime it works.
>Remember: in OS X the time to import a big shape files depends from
>MHz but it's fast. Your problem is a bug in Grass with some shape
>files and if you see all this time you Stop the Process of v.in.ogr
>from Process Viewer (in Utility).
>Bye
>________________________________________________________________________
>||      Lorenzo Moretti        e-mail: lorenzo.moretti at bologna.enea.it
>||/|/|  ENEA prot/idr          Web: http://wwwamb.bologna.enea.it/
>||   |  via Don Fiammelli, 2   FTP: ftp://ftpamb.bologna.enea.it/ (res.)
>~~~~~~  40128 BOLOGNA - ITALY  Ph: +39-0516098086  Fax: +39-0516098131
>			Download GRASS for MAC OS X:
>	           http://wwwamb.bologna.enea.it/forgrass/
Brian Beckage
Department of Botany
University of Vermont
Marsh Life Science Building
Burlington, VT 05405
Phone:  802 656-0197
Fax  :  802 656-0440
email:  Brian.Beckage at uvm.edu
web  :  www.uvm.edu/~bbeckage
