[GRASSLIST:6546] Re: problem importing vector
Brian Beckage
Brian.Beckage at uvm.edu
Tue Apr 19 09:50:50 EDT 2005
Hamish,
> > This is an old problem from grass 5.7. Grass with some shape files
>> (only some) goes to infinite loop in Mac OS X only.
>I think it can be finite, just really slow. Is CPU use at 100% or 0%?
>Multiple bugs here, need to figure out which one you are seeing :)
The CPU is at 100% and appears to be making progress. I suspect that
if I wait long enough, it will work. If I renice the job as you
suggest, then I think this may be manageable.
Alternatively, I have another (fast) machine in my lab that is mostly
idle. If I import this vector into Grass using this other machine,
is there an easy method for transferring this vector from one machine
to another without having to do the time consuming 'cleaning' again?
Is there some sort of Grass-object or some other format that allows
vectors to be moved between machines without having to be reprocessed?
>I think for the coastline case, it is just slow; depends on the data.
>Long complicated polygons take heaps of time on Linux too.
The polygons are very complicated and so I think this is the case.
I've been able to successfully import other vectors as shape files
without any trouble.
Brian
Brian Beckage
Department of Botany
University of Vermont
Marsh Life Science Building
Burlington, VT 05405
Phone: 802 656-0197
Fax : 802 656-0440
email: Brian.Beckage at uvm.edu
web : www.uvm.edu/~bbeckage
