[GRASSLIST:6585] Re: [GRASS5] Re: Re: problem importing vector
Lorenzo Moretti
lorenzo.moretti at bologna.enea.it
Thu Apr 21 10:51:04 EDT 2005
Hi Hamish
> > >Hamish
>> I've applied your PATCH to vector/v.in.ogr/geom.c.
>> All OS X users can download last cvs version (050419) with this patch
>> at: http://wwwamb.bologna.enea.it/forgrass/downloadcvs.htm.
>> I have tried with some old shape that have problems in Grass with
>> normal: v.in.ogr -o
>> ... and I have the same problems than before: infinite loop. I have
>> killed v.in.ogr.
>that patch was non-functional, it still needs some work. It won't do any
>harm though, as it won't do anything at all.
>I used
>#ifdef UNUSED
>#endif
>for commenting out a chunk of code which contains other /* comments */.
>> I have retry the same commands from wish app in X11 and AQUA
>> environment (graphic method) (v.type in graphic window is not good)
>(as Radim noted, you don't actually need the v.type steps after all)
Is this sufficient for complex shape files that don't work with
normal "v.in.ogr -o"?
- v.in.ogr -c -o
- v.clean tool=break
>is the v.clean problem a result of you needing GUI options like:
>(choose only one)
>o line,boundary
>o boundary,line
>o point,centroid
>o centroid,point
This list is the best solution for v.type command window
>and not as now:
>(choose multiple)
>o line
>o boundary
>o centroid
>o point
>and then somehow know that you are only allowed to select two compatible
>ones from the list and somehow specify order (impossible)?
Now it's impossible to select "boundary,line" in v.type window.
>> but v.clean send to crash my Wish app, only wish app.
>> Why wish app is more unstable with some commands with some vector layer?
>no idea. Could it be warning / error messages triggering the crash?
>G_percent?
>maybe debug with:
> v.clean --tcltk | less
I want to test beter...
Thanx
________________________________________________________________________
|| Lorenzo Moretti e-mail: lorenzo.moretti at bologna.enea.it
||/|/| ENEA prot/idr Web: http://wwwamb.bologna.enea.it/
|| | via Don Fiammelli, 2 FTP: ftp://ftpamb.bologna.enea.it/ (ris.)
~~~~~~ 40128 BOLOGNA - ITALY Ph: +39-0516098086 Fax: +39-0516098131
