[GRASSLIST:6687] Re: Error in startup script: ps.map:
Stefano Costa stefano.costa at email.it
Sat Apr 30 15:48:39 EDT 2005
  > GDAL is a mandatory dependency for GRASS 6.x. You can obtain it from:
> 	http://www.gdal.org/
> If you already have it, and it's installed in /usr/local/lib, check
> that /usr/local/lib is listed in /etc/ld.so.conf; if it isn't, add it
> then run "ldconfig".
I only get
> GRASS 6.0.0 (abbubu):/etc > Error in startup script: couldn't execute "ps.map": no such file or directory
>     while executing
> "exec ps.map -p"
>     (procedure "DmPrint::init" line 14)
>     invoked from within
> "DmPrint::init"
>     (procedure "main" line 32)
>     invoked from within
> "main $argc $argv"
>     (file "/usr/lib/grass/etc/dm/d.m.tcl" line 894)
no mention of gdal but GRASS isn't working anyway. anyone who got the
same problem?
Stefano Costa
Visita il mio sito: http://www.iosa.it - Software Open Source per
l'Archeologia
GnuPG Key ID: 1024D/0xD0D30245
Jabber: archeosteko at jabber.linux.it
Per favore non mandarmi allegati Word o PowerPoint.
Puoi utilizzare formati come pdf, html o testo semplice.
Per maggiori informazioni
visita:http://www.fsf.org/philosophy/no-word-attachments.it.html
