[GRASSLIST:7760] RE: cross validation on v.srf.rst. Does it work?
Jaime Carrera
jaicarrerahdez at yahoo.com
Tue Aug 2 09:17:12 EDT 2005
Hi Tom
But I think that the values I get from running
v.srf.rst and the difference between the interpolated
map and the real value should be the same no matter
what value I use for smoothing. Am I right?
Jaime
--- Tom Colson <tom_colson at ncsu.edu> escribió:
> Just for grins..try smooth=.01 or .02. My first
> suspicion would be that
> there is too much smoothing. How many points are in
> the rainfall data
> set...and what is the average distance between
> points?
> Thomas Colson
> North Carolina State University
> Department of Forestry and Environmental Resources
> (919) 673 8023
> Calendar:
> www4.ncsu.edu/~tpcolson
> -----Original Message-----
> From: owner-GRASSLIST at baylor.edu
> [mailto:owner-GRASSLIST at baylor.edu] On
> Behalf Of Jaime Carrera
> Sent: Tuesday, August 02, 2005 8:57 AM
> To: grasslist at baylor.edu
> Subject: [GRASSLIST:7758] cross validation on
> Hi all,
> I'm trying to use the cross validation option on
> both v.srf.rst and
> v.vol.rst. However I'm getting some strange results
> for the slovakia
> rainfall data set.
> 1) I ran v.srf.rst as follows:
> GRASS 6.0.0 (slovakia3d):~ > v.surf.rst input=rain3d
> zcolumn=int_1 cvdev=cv1 -v mask=mask at PERMANENT
> Which wrote a table with difference values on
> Postgres.
> 2) Then I created another table without the gauging
> station #122 (which I
> called rain3d_2) and interpolated using the same
> parameters as above:
> input=rain3d_2 zcolumn=rain
> mask=mask at PERMANENT elev=vsurf1_wo122
> AFAIK cross validation removes one point at a time,
> interpolates using the
> remainder points and computes the difference between
> the interpolated value
> at a certain location (i.e. station 122) and the
> real value (record at
> station 122). Accordingly if I query the raster map
> vsurf1_wo122 at the
> coordinates of station
> 122 and substract the interpolated value to the real
> value I should get the
> value that was written to the cross validation table
> for station 122, so I
> query the
> map:
> GRASS 6.0.0 (slovakia3d):~ > r.what
> input=vsurf1_wo122
> east_north=4416904,5414029
> 4416904|5414029||1057.9642333984
> The real value at station 122 is 798 mm; according
> to these values the
> difference is: 1057.96-798 = 259.96.
> The value that was written by the v.srf.rst module
> on the cross-validation
> table is -5.31.
> Can someone tell me what's going on here?
> Cheers,
> Jaime
> __________________________________________________
> Correo Yahoo!
> Espacio para todos tus mensajes, antivirus y
> antispam ¡gratis!
> Regístrate ya - http://correo.espanol.yahoo.com/
Correo Yahoo!
Espacio para todos tus mensajes, antivirus y antispam ¡gratis!
