[GRASSLIST:7766] Re: interactive modification of cell elevation
Markus Neteler
neteler at itc.it
Wed Aug 3 05:53:36 EDT 2005
Karl,
did you try d.rast.edit?
http://grass.itc.it/grass60/manuals/html60_user/d.rast.edit.html
"The d.rast.edit program allows users to interactively edit cell category values in a raster map layer displayed to the graphics monitor using a mouse cursor."
I'm not sure if it is updated for floating point maps.
Markus
On Tue, Aug 02, 2005 at 09:06:39AM -0700, Ian MacMillan wrote:
> Karl,
> r.digit allows you to draw new raster lines and areas. From that you
> can r.patch the new raster and your old raster together. There may be
> other ways as well.
> G'luck,
> Ian
> On Aug 2, 2005, at 6:15 AM, Karl Broich wrote:
> >Hello,
> >does GRASS allow for interactive modification of elevations? Within a
> >huge data file I just need to modify a couple of cells.
> >Thanks for your help in advance,
> >Karl Broich
> >Dr.-Ing. Karl BROICH Tel: +49 / (0) 89 / 6004 2478
> >Universität der Bundeswehr München Fax: +49 / (0) 89 / 6004 3858
> >Institut für Wasserwesen
> >Werner-Heisenberg-Weg 39
> >D 85577 Neubiberg
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
