[GRASSLIST:7767] Re: interactive modification of cell elevation (solved)
    Karl Broich
    b61bro at b61srv5.bauv.unibw-muenchen.de
    Wed Aug  3 10:30:07 EDT 2005
Markus, Ian,
I can use both methodologies:
d.rast.edit for single cell manipulation and r.digit+r.patch for areas with
modified constant elevations.
thanks a lot,
Karl
At 11:53 03.08.2005 +0200, you wrote:
>Karl,
>did you try d.rast.edit?
>  http://grass.itc.it/grass60/manuals/html60_user/d.rast.edit.html
>  "The d.rast.edit program allows users to interactively edit cell
> category values in a raster map layer displayed to the graphics monitor
> using a mouse cursor."
>I'm not sure if it is updated for floating point maps.
>Markus
>On Tue, Aug 02, 2005 at 09:06:39AM -0700, Ian MacMillan wrote:
> > Karl,
> > r.digit allows you to draw new raster lines and areas.  From that you
> > can r.patch the new raster and your old raster together.  There may be
> > other ways as well.
> > G'luck,
> > Ian
> > On Aug 2, 2005, at 6:15 AM, Karl Broich wrote:
> > >Hello,
> > >does GRASS allow for interactive modification of elevations? Within a
> > >huge data file I just need to modify a couple of cells.
> > >Thanks for your help in advance,
> > >Karl Broich
> > >Dr.-Ing. Karl BROICH                 Tel:    +49 / (0) 89 / 6004 2478
> > >Universität der Bundeswehr München   Fax:    +49 / (0) 89 / 6004 3858
> > >Institut für Wasserwesen
> > >Werner-Heisenberg-Weg 39
> > >D 85577 Neubiberg
>Markus Neteler     <neteler itc it>       http://mpa.itc.it
>ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
>MPBA - Predictive Models for Biol. & Environ. Data Analysis
>Via Sommarive, 18        -       38050 Povo (Trento), Italy
D 85577 Neubiberg
