[GRASSLIST:7777] Re: "densifying" or adding vertices to breaklines
Jean-Denis Giguere
jdenisgiguere at fastmail.fm
Wed Aug 3 19:17:06 EDT 2005
Hi Tyler,
You can use v.to.points to create points along your contour lines.
After, you should use v.patch to combine your points layer.
Sadly, I can't explain you how to create your attribute table when you
do your v.patch command. I ask a question about that this morning but I
don't get an answer by now.
There is also some parameters that can be pass to v.surf.rst to deal
with this.
Hope this help,
Jean-Denis
Tyler Mitchell wrote:
> We're looking to add points from breaklines into our DEM point maps, so
> we can do terrain analysis. Is there a similar concept in GRASS for
> doing this? Perhaps this is the way to do it, let me know if you have
> any ideas.
> Tyler
