[GRASSLIST:7778] Re: "densifying" or adding vertices to breaklines
    Tyler Mitchell
    tjm at timberline.ca
    Wed Aug  3 19:33:32 EDT 2005
Merci JD, I now understand better what you meant.  It sounds like we are
after the same thing - now we just need some help! :)
Tyler
Jean-Denis Giguere wrote:
> Hi Tyler,
> You can use v.to.points to create points along your contour lines.
> After, you should use v.patch to combine your points layer.
> Sadly, I can't explain you how to create your attribute table when you
> do your v.patch command. I ask a question about that this morning but I
> don't get an answer by now.
> There is also some parameters that can be pass to v.surf.rst to deal
> with this.
> Hope this help,
> Jean-Denis
> Tyler Mitchell wrote:
>> We're looking to add points from breaklines into our DEM point maps,
>> so we can do terrain analysis.  Is there a similar concept in GRASS
>> for doing this?  Perhaps this is the way to do it, let me know if you
>> have any ideas.
>> Tyler
