[GRASSLIST:7785] Re: vectors creation and attributes table
Markus Neteler
neteler at itc.it
Thu Aug 4 06:07:45 EDT 2005
On Wed, Aug 03, 2005 at 12:09:46PM -0400, Jean-Denis Giguere wrote:
> Hi all,
> GRASS6 improve greatly vector attribute management. Sadly, it seems that
> some vector commands do not support natively copy of attributes. By
> example, I would like to use v.split on contour lines to obtain more
> points and use them with v.surf.rst. The elevation is one of the
> attributes on my contour lines vector table. Is there a trick to attach
> attribute to new vector ?
In a couple of modules the full attribute support is still missing.
Programmers welcome!
As workaround you can use v.category and then link to the new
cats.
Markus
