[GRASSLIST:7802] Re: vectors creation and attributes table
Radim Blazek
radim.blazek at gmail.com
Fri Aug 5 04:22:22 EDT 2005
AFAIK, v.surf.rst adds points along lines.
Radim
On 8/3/05, Jean-Denis Giguere <jdenisgiguere at fastmail.fm> wrote:
> Hi all,
> GRASS6 improve greatly vector attribute management. Sadly, it seems that
> some vector commands do not support natively copy of attributes. By
> example, I would like to use v.split on contour lines to obtain more
> points and use them with v.surf.rst. The elevation is one of the
> attributes on my contour lines vector table. Is there a trick to attach
> attribute to new vector ?
> Best regards,
> Jean-Denis
