[GRASSLIST:7795] Re: r.cost execution time
Ellen De Beuckeleer
ellen.debeuckeleer at incgeo.be
Fri Aug 5 02:25:57 EDT 2005
Hi all,
the problem is not solved. My r.cost is still running :(.
Any suggestions?
Ellen
Ellen De Beuckeleer wrote:
> Oeps, it seems like the default maximal cost given in the GUI is 0???
> This might be the problem. I ame rerunning the line below without the
> max_cost=0 (stupid me...). Hope this will solve the problem.... it is
> now running for 4 minutes, so I let you know if it is actually solved
> somewhere later today, tomorrow...?
> Ellen
>> Dear list,
>> I want to compute a cost surface using r.cost. I used the GRASS user
>> interface to input the parameters which resulted in the following line:
>> r.cost input=costTotal output=costsurface coordinate=-10698,-7021
>> stop_coordinate=-1216,-221 max_cost=0 percent_memory=25.
>> I didn't use the -k option as this needs longer execution time and I
>> ame only testing at the moment, but my proces is already running for
>> over 1000 minutes. Is this normal (image dimensions: 640x480)? If so
>> how can I estimate the remaining execution time? If not: what's going
>> wrong?
>> Greetz,
>> Ellen
IncGEO
Kempische steenweg 297 bus 2
3500 Hasselt
tel: +32 (0)11 45 20 16
fax: +32 (0)11 45 20 17
www.incgeo.be
