[GRASSLIST:7797] Re: NVIZ and 3d vectors
Markus Neteler
neteler at itc.it
Fri Aug 5 03:21:09 EDT 2005
(cc Radim)
On Thu, Aug 04, 2005 at 10:49:08PM -0700, Michael Barton wrote:
> There are some folks here at ASU who are interested in doing this kind of 3D
> generation.
> It would help, I think if we could at least see what the ascii files are
> like that generated the tower and houses,
Due to copyright restrictions I am not permitted to publish these
files of the 3D tower.
Maybe Radim can publish the house example.
> and the tree algorithm (if
> different from Jachym's perl script in the WIKI).
I only know the tree algorithm in the WIKI.
You have to use the "Faces" to make 3D surfaces. We should add
a simple example to the v.in.ascii HTML page.
Markus
> Thanks
> Michael
> On 8/4/05 1:05 AM, "Markus Neteler" <neteler at itc.it> wrote:
> > On Wed, Aug 03, 2005 at 09:22:09PM -0400, Jean-Denis Giguere wrote:
> >> Hi all !
> >> If you go on the GRASS 6 homepage
> >> (http://grass.itc.it/grass60/index.php), you will find very interesting
> >> snapshots that represent 3d views of a digital elevation model plus 3D
> >> vectors (see http://grass.itc.it/images/grass51trees.jpg and
> >> http://grass.itc.it/images/grass51_nviz.jpg)
> >> I can't find any documentation about how to import and/or create such 3D
> >> vectors and vizualize them into nviz. I would really appreciate if
> >> someone could point me a tutorial or a draft procedure to create this
> >> kind of image.
> > The towers and houses were lovingly handcrafted using vim (by Radim).
> > The trees were done with a tree algorithm. Both generated as 3D ASCII
> > files, then imported with v.in.ascii.
> > It would be cool to have a program which takes 2D polygons and an
> > attribute column to generate 3D boxes (approximation of houses).
> > Markus
> ____________________
> C. Michael Barton, Professor of Anthropology
> School of Human Evolution and Social Change
> PO Box 872402
> Arizona State University
> Tempe, AZ 85287-2402
> USA
> Phone: 480-965-6262
> Fax: 480-965-7671
> www: <www.public.asu.edu/~cmbarton>
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
