[GRASSLIST:7814] Re: NVIZ problems
Markus Neteler neteler at itc.it
Mon Aug 8 05:53:21 EDT 2005
Mark,
On Sat, Aug 06, 2005 at 10:47:08AM +0100, mark balman wrote:
> Hi all
> I have installed Grass 6.0 onto an AMD 64 platform running SUSE 9.2
> Pro 64 bit and it works fab, but I cannot seem to get NVIZ to work (a
> shame because I would like to do some 3d visualisation projects).
I have access to a 64bit RHEL4 box.
> My errors specifically are:
> Application initialization failed: Can't find a usable init.tcl in the
> following directories:
>    /usr/lib/tcl8.4 /usr/local/grass-6.0.0/lib/tcl8.4
> /usr/local/lib/tcl8.4 /usr/local/grass-6.0.0/library
> /usr/local/library /usr/local/tcl8.4.7/library /usr/tcl8.4.7/library
> /usr/lib/tcl8.4
> so, I created /usr/lib64/tcl8.4 and set a symlink
> ln -s /usr/lib64/tcl8.4/init.tcl /usr/lib/tcl8.4/init.tcl
> Alas no go..
> Has anyone else had this problem and if so any ideas would be most
> gratefully received.. beers to all!
Mine stays here:
 /usr/share/tcl8.4/init.tcl
I configured like this:
# with debugging:
export CFLAGS='-g -Wall'
# RHEL 4:
./configure \
  --enable-64bit \
  --with-libs=/usr/lib64 \
  --with-cxx \
  --with-gdal=/usr/local/bin/gdal-config \
  --with-postgres-includes=/usr/include/pgsql --with-postgres-libs=/usr/lib \
  --without-mysql \
  --without-odbc \
  --with-motif \
  --with-motif-includes=/usr/X11R6/include/Xm \
  --with-glw \
  --with-nls \
  --with-fftw \
  --with-freetype --with-freetype-includes=/usr/include/freetype2 \
  --enable-largefile \
  --without-opendwg \
  2>&1 | tee config_log.txt
Note that I had to compile FFTW2 like this:
 CFLAGS="-fPIC" ./configure
Hope this helps
 Markus
