[GRASSLIST:7839] Re: raster conversion problem
Tue Aug 9 16:25:03 EDT 2005
Okke Batelaan wrote:
> a long time ago...(> 10 years) I was an intensive GRASS user.
> Unhappily, I have now no access to an unix/linux machine with GRASS.
> I want now to convert the two attached GRASS (4.2) packed binary integer
> raster files to ascii grids. Could somebody help me?
I'll email you the converted files.
> Or is there somewhere a tool to do this in windows?
GRASS can be run on Windows using Cygwin, although it's a bit more
awkward to set up (mostly because you have to get your Cygwin
environment set up right).
