Jachym Cepicky wrote: > what about region? > > g.region -dp > > g.region rast=rast.red > d.rast rast.red If this works, it probably means that the .tfw file was ignored, in which case you need to use r.region to correct the map's position. -- Glynn Clements <glynn at gclements.plus.com>
