[GRASSLIST:7861] Re: r.in.gdal tiff problem
Michele
michele.rocc at libero.it
Thu Aug 11 10:06:56 EDT 2005
I prepared a new location and it works, the problem was that I was using an old location from a backup and there was somethig wrong with the proj parameters in that old one, sorry ;-)
Thanks!
> Jachym Cepicky wrote:
> > what about region?
> > g.region -dp
> > g.region rast=rast.red
> > d.rast rast.red
> If this works, it probably means that the .tfw file was ignored, in
> which case you need to use r.region to correct the map's position.
> Glynn Clements <glynn at gclements.plus.com>
____________________________________________________________
Libero Flat, sempre a 4 Mega a 19,95 euro al mese!
Abbonati subito su http://www.libero.it
