[GRASSLIST:7913] Re: r.proj takes a very long time / does not complete
Ian MacMillan
ian_macmillan at umail.ucsb.edu
Mon Aug 15 17:25:30 EDT 2005
A simple way to do this is to make a vector box of your region in the
first location using v.in.region. Go to your new location, v.proj that
vector in, and set your region to the new vector. Then use r.proj on
the raster you want to project. You will still have to set the
resolution on your own though. Hope this makes sense.
-Ian
On Aug 15, 2005, at 2:14 PM, Morten Hulden wrote:
> No wonder it takes forever. Your output location has 527482690275
> cells (847325 x 622527) to project.
> You should adjust the boundaries or resolution of your NAD83 location
> to something more reasonable. Before running r.proj try to set a
> resolution value that roughly matches the resolution of your input map
> (g.region res= ), e.g. something like 1000 m.
> Don't know about boundaries for your location (TX unknown area to me)
> but you may want to check those as well. No need to cover more than
> what is necessary.
> rgds
> Morten
> Jason Horn wrote:
>> Morten,
>> Thanks for looking at this for me. Below are the files you asked for.
>> PROJ_INFO for the source lat-lon location:
>> datum: wgs84
>> towgs84: 0.000,0.000,0.000
>> proj: ll
>> ellps: wgs84
>> cellhd file for KEWX20040710_025420:
>> proj: 3
>> zone: 0
>> north: 34:00:17.832478N
>> south: 25:11:59.799175N
>> east: 92:43:25.599215W
>> west: 103:19:56.000785W
>> cols: 1000
>> rows: 830
>> e-w resol: 0:00:38.190402
>> n-s resol: 0:00:38.190402
>> format: -1
>> compressed: 1
>> PROJ_INFO file for the destination NAD83 location:
>> name: Lambert Conformal Conic
>> datum: nad83
>> proj: lcc
>> ellps: grs80
>> a: 6378137.0000000000
>> es: 0.0066943800
>> f: 298.2572221010
>> lat_0: 31.1666670000
>> lat_1: 27.4166670000
>> lat_2: 34.9166670000
>> lon_0: -100.0000000000
>> x_0: 1000000.0000000000
>> y_0: 1000000.0000000000
>> WIND file for the destination NAD83 location:
>> proj: 99
>> zone: 0
>> north: 1196061
>> south: 573534
>> east: 1563147
>> west: 715822
>> cols: 847325
>> rows: 622527
>> e-w resol: 1
>> n-s resol: 1
>> top: 1
>> bottom: 0
>> cols3: 847325
>> rows3: 622527
>> depths: 1
>> e-w resol3: 1
>> n-s resol3: 1
>> t-b resol: 1
>> Thanks again!
>> - Jason
>> On Aug 13, 2005, at 12:14 PM, Morten Hulden wrote:
>>> Jason Horn wrote:
>>>> I have a long-standing problem with r.proj. I have never been
>>>> able to complete a successful re-projection of a raster file. For
>>>> example, I am trying to pull in a raster file from a location that
>>>> is lat-lon, WGS84 into a location that is state-plane meters,
>>>> NAD83. The raster grid is relatively small, 1000 cols by 830
>>>> rows. I start r.proj like this:
>>>> r.proj input=KEWX20040710_025420 location=TX_ll_WGS84
>>>> mapset=PERMANENT output=proj1 method=nearest Although my CPU stays
>>>> pegged at close to 100% usage, the progress bar never moves
>>>> forward and nothing happens, even if I leave it for many hours.
>>>> Can anyone tell me what's going on here?
>>> In order to help you I would like to see:
>>> 1) The PROJ_INFO file for your latlon location
>>> 2) The cellhd file of the KEWX20040710_025420 map in the latlon
>>> location
>>> 3) The PROJ_INFO file for your NAD83 location
>>> 4) The WIND file for your NAD83 location
