[GRASSLIST:7924] Re: R Stats and GRASS primer (wanted)
Feng Tan
feng at lynxseismicdata.com
Tue Aug 16 12:38:10 EDT 2005
Hi, List,
Thanks for your help!! I have successfully installed GRASS6.0/R. It works on
spearfish test dataset. But when I run my own dataset which have worked for
GRASS5.7/R does not work for GRASS6.0/R, it said:"cannot find function
rast.get() ". Please help!!
Thanks!
Feng
On Saturday 23 July 2005 02:04, Markus Neteler wrote:
> Hi Feng,
> I always launched update.packages() before installing the
> sp things. Then a Tcl window pops up where I select a mirror
> site.
> Or: probably you tcl/tk libraries are not installed [properly]?
> Markus
> On Fri, Jul 22, 2005 at 09:23:44AM -0600, Feng Tan wrote:
> > hi, Markus,
> > When I installing the R/GRASS6.0 interface using your instruction , the
> > following error showed:
> > > install.packages(c("sp","rgdal","maptools"), dependencies=TRUE)
> > --- Please select a CRAN mirror for use in this session ---
> > Error in inherits(x, "factor") : Object "res" not found
> > what happened?
> > Thanks,
> > Feng
> > On Thursday 21 July 2005 03:15, Markus Neteler wrote:
> > > [GRASSLIST:7657] Re: R Stats and GRASS primer (wanted)
> > > From:
> > > Markus Neteler
