[GRASSLIST:7925] Re: R Stats and GRASS primer (wanted)
Thomas Adams
Thomas.Adams at noaa.gov
Tue Aug 16 12:54:06 EDT 2005
Feng,
Go to CRAN (http://cran.r-project.org/) to the Newsletter section and
get the Volume 5/1, May 2005 issue. There is an article on the new
GRASS/R interface that's needed with R 2.1 & GRASS 6.x. Hope this helps.
Tom
Feng Tan wrote:
>Hi, List,
>Thanks for your help!! I have successfully installed GRASS6.0/R. It works on
>spearfish test dataset. But when I run my own dataset which have worked for
>GRASS5.7/R does not work for GRASS6.0/R, it said:"cannot find function
>rast.get() ". Please help!!
>Thanks!
>Feng
>On Saturday 23 July 2005 02:04, Markus Neteler wrote:
>>Hi Feng,
>>I always launched update.packages() before installing the
>>sp things. Then a Tcl window pops up where I select a mirror
>>site.
>>Or: probably you tcl/tk libraries are not installed [properly]?
>>Markus
>>On Fri, Jul 22, 2005 at 09:23:44AM -0600, Feng Tan wrote:
>>>hi, Markus,
>>>When I installing the R/GRASS6.0 interface using your instruction , the
>>>following error showed:
>>>>install.packages(c("sp","rgdal","maptools"), dependencies=TRUE)
>>>--- Please select a CRAN mirror for use in this session ---
>>>Error in inherits(x, "factor") : Object "res" not found
>>>what happened?
>>>Thanks,
>>>Feng
>>>On Thursday 21 July 2005 03:15, Markus Neteler wrote:
>>>>[GRASSLIST:7657] Re: R Stats and GRASS primer (wanted)
>>>>From:
>>>>Markus Neteler
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL: thomas.adams at noaa.gov
VOICE: 937-383-0528
FAX: 937-383-0033
