[GRASSLIST:8049] Problem loading shared libs in GRASS 6.1
Thomas Adams Thomas.Adams at noaa.gov
Wed Aug 24 13:52:50 EDT 2005
List:
I have installed GRASS 6.0.1 & 6.1CVS on a linux system in a networked
environment; all the linux systems are configured identically. All of
the supporting libs and programs, such as, gdal, netcdf, proj4, etc., as
well as GRASS were built in a directory in everyone's PATH (using
configure --prefix=INSTALL/PATH/for/whatever) on a nfs mounted volume.
Consequently, nothing was installed locally in /usr/local/lib,
/usr/local/bin, etc.
I have no problem bringing grass61 up on the machine where I did all my
work. However, if I go to another networked machine, everything works
fine **until** I push the button to "Enter GRASS", at which point I get
a message that a shared library can not be found for gdal. Someone else
logging into the machine where in did the installations gets the can't
find shared library error (where I had none). In fact, anyone trying to
startup GRASS from any other machine gets the "can't find shared
library" error.
Obviously, I am missing something to allow grass6x to run in a networked
environment; what is that?
Regards,
Tom
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL:	thomas.adams at noaa.gov
VOICE:	937-383-0528
FAX:	937-383-0033
