[GRASSLIST:8078] Re: v.out.ogr to PostgreSQL
orkun
temiz at deprem.gov.tr
Fri Aug 26 06:56:26 EDT 2005
Stephan Holl wrote:
>Hello orkun,
>On Fri, 26 Aug 2005 11:56:46 +0300 orkun <temiz at deprem.gov.tr> wrote:
>>v.out.ogr input=jeo6 type=area dsn="PG:host=localhost dbname=bzk
>>user=orkun" olayer=sil7 format=PostgreSQL
>>ERROR 1: AddGeometryColumn failed for layer sil7, layer creation has
>>failed. ERROR: Cannot create layer
>It looks like this db does not have postGIS enabled?!
>So enable the db with postgis-support.
>If you just want to store attribute-information have a look at the
>newly created wiki-entry[1].
>There ist describes how to set up postgres for attribute storage.
>hth
> Stephan
>[1]
>http://grass.gdf-hannover.de/twiki/bin/view/GRASS/GrassSixTutorialFaq#11_Use_Postgres_as_attribute_sto
thank you
the db I used (bzk) has already been enabled with postGIS.
as "user postgres" in sql environment (out of grass), it works.
bzk=# CREATE TABLE gtest3 ( ID int4, NAME varchar(20) );
CREATE TABLE
bzk=# SELECT AddGeometryColumn('gtest3','geom',-1,'POLYGON',2);
addgeometrycolumn
public.gtest3.geom SRID:-1 TYPE:POLYGON DIMS:2
geometry_column fixed:0
(1 row)
the problem (I think) is related to:
my newer postgresql (8..) version enabled postgis. But grass only connects
older postgre (7.4..).
So how can make grass work only newer postgresql ?
how about different user other than user postgres in using v.out.ogr ?
regards
______________________________________
XamimeLT - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster at deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
