[GRASSLIST:8108] Re:postgresql connection failes
orkun
temiz at deprem.gov.tr
Mon Aug 29 04:06:06 EDT 2005
Michele wrote:
>Hi,
>You can recompile GRASS with the new path to postgresql specified in the "./configure" step:
>../configure \
>--with-postgres-includes=/new/path/to/postgres/include/ \
>--with-postgres-libs=/new/path/to/postgres/lib/ \
>Michele.
>>hello
>>after installation grass with posgresql support,
>>I reinstalled postgresql from source in different location.
>>Consequently, grass can not link to postgresql which I had
>>been able to connect to.
>>How can I ensure that grass can connect to postrgresql ?
>>regards
>>Ahmet Temiz
>____________________________________________________________
>Libero Flat, sempre a 4 Mega a 19,95 euro al mese!
>Abbonati subito su http://www.libero.it
thank you
but although I recompiled grass with new path of postgresql, it gives
error in using :
db.tables driver=pg database=bzk
(after db.connect driver=pg database=bzk)
DBMI-Postgres driver error:
Cannot connect to Postgres: could not connect to server: No such file or
directory
Is the server running locally and accepting
connections on Unix domain socket "/var/run/postgresql/.s.PGSQL.5432"?
What should be done else ?
regards
XamimeLT - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster at deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
