[GRASSLIST:8128] Re: V.digit (GRASS): Layer disapears, using QGIS as front end
Radim Blazek
radim.blazek at gmail.com
Tue Aug 30 04:33:55 EDT 2005
On 8/29/05, Dave Sampson <gis at watersheds.ca> wrote:
> Radim Blazek,
> When I go into QGIS with the dumby file (say a square). If I start
> digitizing again (this time a circle in QGIS) then go back and delete
> the original feature (square) then everything is OK.
> However if I delete the original feature (square) before the digitizing
> a new feature in QGIS (circle) then it goes CUBAR (Hard 'C' (eg K),
> Currupted beyond all recog).
> QGIS and GRASS can't use the file anymore, even with tryinh to rebuild
> topography.
Strange, I cannot reproduce it. The corrupted file contains feature or did
you
get the problem when it was empty? What v.build prints for that map?
Radim
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20050830/19df348a/attachment.html
