[GRASSLIST:9273] DBMI errors after QGIS+GRASS crash
Dylan Beaudette
dylan.beaudette at gmail.com
Fri Dec 2 14:24:49 EST 2005
Greetings.
I was editing a GRASS vector layer in QGIS, specifically the attribute table-
which stored in MySQL. Everything was working fine, until I tried to access
the same vector layer in the GRASS shell. An error was returned regarding
something about the header missing some this vector, and QGIS suddenly quit.
Afterwards, any time i try and access the attributes for this vector via
GRASS I get:
echo "select * from merged_dupes" | db.select
dbmi: Protocol error
...despite the fact that all of the data is still in MySQL, and the table
checks out OK. I have re-issued the db.connect, and v.db.connect commands in
hopes that that would fix the connection.
Also- now when i try and start QGIS from within this mapset and load the
trouble vector layer, QGIS quits with a "dbmi ERROR".
I have tried replacing my mapset with a known working copy, but that refuses
to work as well. Trying to copy the trouble vector results in a DBMI error as
well.
Any ideas??
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
