[GRASSLIST:9287] Re: Rotate raster
Michele michele.rocc at libero.it
Sun Dec 4 04:51:39 EST 2005
Well, if you need to rotate and don't need georeferenced images, you can
use "Imagemagick" from the command line, so that you can insert it in a
scrip for batch processing purposes.
Almost any image manipulation program, like "The GIMP" will do that...
Michele.
Nick Cahill wrote:
> I have a number of rasters which are oriented with north at the right
> rather than at the top. Other than using i.rectify is there a simple
> way in GRASS to just rotate the image 90 degrees?
> Thanks,
> Nick Cahill
