[GRASSLIST:9302] Re: draw line from (x,y) point and bearing [solved: new module]
Dylan Beaudette dylan.beaudette at gmail.com
Mon Dec 5 12:23:08 EST 2005
On Dec 4, 2005, at 8:01 PM, Hamish wrote:
>>> does anyone know of a module (d.*, v.*, r.* ??) that will accept a
>>> point and a bearing, and draw the line on the active monitor?
>> Looks like necessity is the mother of invention. Solved this problem
>> with a shiny new module d.bearing:
>> The new module solves the problem I had (plot a transect from x,y
>> along bearing theta, to given radius) and will optionally save the
>> result as a new vector.
> It's quite nice when you can make modules to do exactly what you need
> done... but fyi, see also:
> d.geodesic
> d.rhumbline
> r.profile
> r.transect
> d.mapgraph (hopefully merged into d.graph soon)
> v.in.ascii format=standard
> (and as mentioned m.cogo from GRASS 5)
> Hamish
Thanks for the head up on this. I had researched using v.out.ascii,
d.mapgraph , awk, and finally v.in.ascii all wrapped in a BASH
script... but it seemed a little cumbersome for the work I am doing. If
d.bearing is has too much overlap with other modules, then I will post
it on the GRASS Wiki for curious users. Or perhaps, some additional
functionality or consolidation of functionality would be best.
Cheers,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
