[GRASSLIST:9298] Re: draw line from (x,y) point and bearing
[solved: new module]
Hamish
hamish_nospam at yahoo.com
Sun Dec 4 23:01:42 EST 2005
> > does anyone know of a module (d.*, v.*, r.* ??) that will accept a
> > point and a bearing, and draw the line on the active monitor?
> Looks like necessity is the mother of invention. Solved this problem
> with a shiny new module d.bearing:
> The new module solves the problem I had (plot a transect from x,y
> along bearing theta, to given radius) and will optionally save the
> result as a new vector.
It's quite nice when you can make modules to do exactly what you need
done... but fyi, see also:
d.geodesic
d.rhumbline
r.profile
r.transect
d.mapgraph (hopefully merged into d.graph soon)
v.in.ascii format=standard
(and as mentioned m.cogo from GRASS 5)
Hamish
