[GRASSLIST:9330] Re:v.in.ascii
David Kindem dkindem at chartermi.net
Tue Dec 6 06:35:44 EST 2005
It is a little weird, and persistent, too.
I continue to get the malloc error with any text file i create.  It's
been a while since I used v.in.ascii, so I tried recreating a sites
layer with a text file that worked a few months ago, and get the
malloc error there, too.
Dave
On Dec 6, 2005, at 4:25 AM, Hamish wrote:
>> Did you make sure that you have Unix line feeds at the end of each
>> line? I use TextWrangler to do this. nedit (for x11) also works for
>> this.
> Note v.in.ascii uses G_getl2() now in the GRASS 6.1 development
> version.
> This means dos, unix, and mac os9 newline formats are all understood
> correctly. (Please report any problems.)
> A malloc error is weird to see.
> Hamish
